Store value within a loop
Dear all,
Let's say I am sweeping a voltage source within an infinite while loop via the iteration value "i" and for each voltage "V" I measure the output power "P" from another device.
Questions:
1. I would like to store within a variable the value V=Vp when a certain power P=p is read within the loop. How do I store this value for later use?
2.  I would like to stop the loop when the value 2xVp (2 times Vp) is reached (and that's one of the reasons why I want to store Vp). If I can "clamp" or store Vp somewhere, then I can easily program the condition to stop the loop by simple asking
"Is V >  2xVp".
I understand shift registers may be useful in these kind of cases but  the values stored there always change with "i".
I am new to labview and currently learning by doing. I am sure this is relatively easy to implement but I have tried long time already without success. I have read tutorials and watched videos but I haven't found anything helpful.
Thanks a lot in advance for your comments,
Richard
(6,178 Views)
Hi Richard,
basic LabVIEW stuff: to store values in loop for use in later iterations you shoul duse shift registers.
Wrong.
When "the values change with i", then you have programmed it this way!
Mind to attach your VI?
Did you take those free resources to learn LabVIEW?
(6,174 Views)
Hi, thanks for your reply.
The value of voltage is connected to the iteration value "i" because I am doing a sweep. Therefore, any shift register linked to the voltage will also change with "i".
The example attached illustrates the problem.
The questions reamain:
How can I store the value of the voltage when the "power" is for the first time greater than, say, 0.8?
And then use this value of voltage (let's call it vp) in order to stop the loop at a later time, say, when voltage = 2 x vp ?
Thank you,
(6,152 Views)
Accepted by topic author ricardo81
Hi Richard,
Now we are getting closer to a question with all the facts needed to develop an algorithm!
You need to put in some more logic:
IF power > 0.8 AND flag THEN
  /* store new values */
vp := current voltage flag := FALSE ELSE
/* keep previous values */
vp := vp
flag := flag
ENDIF
The "variables" flag and vp are stored in shift registers.
"flag" needs to be initialized with TRUE, vp with any value you like to…
(6,144 Views)
Thank you!
(6,118 Views)
