Store a value in Labview 7.1
Does LV have the capability of saving a value?  Like in a variable?  I'm using a DO WHILE loop to look at and display data coming in from a serial device.. its real time.  When the vi first starts up I look at one of the values from the serial port and want to store it for later use.  When the user pushes an "aquire" button the inner loop stops, avgs the last 10 readings then subtracts that value from the one I "stored" when the loop 1st started running.
(3,092 Views)
Yes, it does. There's a variety of ways to do this. You could use a local variable, as in create an indicator to which you write the initial value and then read the value when the loop ends (watch for race conditions!). You could also use a shift register. You could also just use a wire, if the code is set up properly. You didn't post your code, so I can only speculate on whether using a simple wire is possible.
(3,084 Views)
Thanks!
(3,079 Views)
