Stopping a Case Sequence
I have a question that I hope someone can help me with.
I currently have this WHILE loop that has a counter in it. The counter will
count from
100 to 0 and when it reaches 0, it will assert a FALSE to indicate that the
100 seconds is
up. With that in mind, I use it to pause my other WHILE loops using a LOCAL
VARIABLE
for 20 seconds.
My problem lies here:
There is a CASE sequence inside the WHILE loop. It will not stop until all
the sequences
have completed. How can I stop a CASE sequence or is there a work-around
solution?
Can anyone offer any suggestions? I would like to post my VI up here so you
can look at it but it's made up of many other sub VIs and the machine is
not networked.
Thanks.
(2,985 Views)
> count from
> 100 seconds is
> VARIABLE
> for 20 seconds.
> the sequences
> solution?
> not networked.
> Thanks.
I think you're confusing things here - there are CASE structures and there are
SEQUENCE structures in LabVIEW. They are very different.
There is no way to stop a Sequence from sequentially stepping through its
entire set of frames. However, a way to get it to do nothing for subsequent
frames (and execute/terminate rapidly) is to put a (boolean) Case structure in
each frame of the Sequence. One frame (case) is "do nothing"; the other
contains the code to be executed in the normal operation. An "upstream" frame
can write to a Sequence Local to control the action downstream. This, however,
is a rather inelegant way to set up what you are trying to do, and becomes
unworkable with more than a few frames.
A much, much better approach is to set up a "state machine," which can be
implemented in LabVIEW using a Case structure inside a while loop; the case
structure can jump to any case when the loop iterates. It's a little too
complicated to explain here. There is an example in NI's Example Programs
Database, search for "state machine," which will return a couple of examples.
The resulting link for a good one ("Pause/Resume & State Machine") is:
http://digital.ni.com/explprog.nsf/2222373937d4e9a38625666a00831a24/f345cd727b37f2f486256568007cfe07?OpenDocument
Good luck and happy wiring,
Rod
Roderic Don
Research Associate II
University of Delaware
Center for Composite Materials
302-831-8701
302-831-8525 (FAX)
(2,985 Views)
>the sequences
Can you just send the same FALSE signal to the case node (and use an OR if
you need to)?
Harry
(2,985 Views)
