Stop if true or continue if true?
It might be a simple question, and I'm just curious.
There is a STOP button and it can be activated with two conditions: Stop if true and Continue if true.
Say, I want to exit a loop. To make this happen, I can do either "STOP -> Stop if true" or "STOP -> NOT -> Continue if true".
I see most of time "STOP -> NOT -> Continue if true" even though it adds one more step "NOT" function.
Is there any reason or just programmer prefers?
(5,560 Views)
Hello:
The selection of "Stop if true" of "Continue if true" depends on the stop condition you will use. For example you may need to keep running a cycle while a digital input is on, so you need to continue if true, or in the other hand you may need to stop when an command is received through a button, so you need to stop if true. It depends on your needs.
In the case you mention, I think it's just a programmer preference.
Robst - CLD
Using LabVIEW since version 7.0
(5,557 Views)
Don't quote me on this, but I would think it's a carryover from hardware conventions/visualization.  You'll also see hardware guys go crazy with XOR, NOR, and NAND gates.
(5,549 Views)
Actually, in older versions of Labview (I think before 6.0), there was no Stop sign, only the continue sign.  Continue while true was the only condition for a while loop.  If you wanted to stop on a true signal, you would have to negate the signal then wire it to the continue icon.  I guess enough people complained and NI introduced the Stop sign.  It was made into a choice for backwards compatibility.  Older programs converted to 6.0 could still use the continue feature, while new programs had to option to stop on true.
- tbob
Inventor of the WORM Global
(5,543 Views)
