Stop While loop
This is my code
Message Edited by enzo78 on 07-09-2008 08:20 AM
Message Edited by enzo78 on 07-09-2008 08:22 AM
Message Edited by enzo78 on 07-09-2008 08:25 AM
Message 11 of 13
(923 Views)
Hi, enzo,
You have demonstrated "copy-paste" programming style above, and its not very good. You have five times almost the same cycle, and now you need to make five times the same changes. At least you can do it much better with SubVIs, or you can join your five cycles into single with cases as shown in attachment.
Andrey.
PS. Disclaimer: in attachment included basic idea only, not "ready for use" solution!
Message 12 of 13
(888 Views)
I realize the copy and paste of the block, because I need to execute them at the same time...
I explain better:
First I choose wich variable I want to save (for example Input state and Output state)
Than I push SAVE
The program must read the variable of Input State and the variable Output state at the same time
The program must save this data at the same time in different export file.
What you have realized allows me to read and save each data not at the same time
Message Edited by enzo78 on 07-09-2008 09:36 AM
Message 13 of 13
(884 Views)
