Stop Labview with DLL
I've written a DLL that LabView calls for many different functions.
In case of a major problem, I would like my DLL to be able to tell LabView
to stop execution of the program. Is there a hook of some type in LabView
that can do this or a window message I can post to LabView?
Bruce Kingsley
brucek@wolfenet.com
(3,887 Views)
> Bruce Kingsley
> brucek@wolfenet.com
I would hope that you are returning error codes from your DLL calls.
If this is true then you can use that code along with either the
Error Handler, or possibly the LV built in "STOP" , "ABORT"
functions.
Kevin Kent
(3,887 Views)
Ken:
Thanks for the response.
The problem is more complex. The DLL is shared by more than just LabView
which makes the DLL aware of events that that LabView may not see; example:
LabView maybe performing file I/O or running a panel, but not calling my
DLL, so there is no error code to return. Since the DLL is always watching
things, it may detect an event that requires LabView to stop.
Bruce Kingsley
brucek@wolfenet.com
Kevin B. Kent wrote in message <3870FD6D.2E8B1AFD@usa.alcatel.com>...
LabView
>> that can
>> Bruce Kingsley
>> brucek@wolfenet.com
>functions.
>Kevin Kent
(3,887 Views)
Could you have your DLL set a flag on an error condition? If so, your
Labview code could check the flag as often as you like, perhaps in a
parallel While loop.
On Mon, 3 Jan #000 16:39:49 -0800, "Bruce Kingsley"
wrote:
>Ken:
>Bruce Kingsley
>brucek@wolfenet.com
>>Br
>LabView
>>> Bruce Kingsley
>>> brucek@wolfenet.com
>>functions.
>>Kevin Kent
(3,887 Views)
