Stitching an Image using 2 USB Cameras
Hello everyone! I have developed a VI which would stitch the images together captured by 2 independent USB Cameras. I am facing a problem. This VI works perfectly when the images are captured by a single camera and stitches them together perfectly but somehow when I apply the same logic to stitch the 2 images captured by different cameras, the 2nd Image appears to be black. Can someone please help me as I have been stuck on this for quite some time?
I have attached the VI and the issue that I am facing.
(1,593 Views)
You have used the same file path for the IMAQ Write File acquisition of both cameras.  I suspect that causes the problem where you don't necessarily have two images since one overwrites the other.
The appending code also seems a little convoluted. Do you really need the For loop?  Why not just specify the first image as 0,0 and then the second at the 0,<width of image 1>?
(1,529 Views)
