Stereo sound generation in LabView 8
something along these lines should do the trick 🙂
Craig
(Loving the code capture tool)
Message Edited by craigc on 02-29-2008 11:31 AM
LabVIEW 2012
Message 11 of 13
(1,080 Views)
Hi Altenbach,
arrgh Smiley Mad - should have noted this either from the terminal or when looking at the front panel... (Usually I have the context help window closed.)
Ok, I learned something today: default datatype for SOWrite is an array of waveforms. Smiley Happy
Message 12 of 13
(1,050 Views)
depending on the waveform creation, one can directly wire the waveforms array to the 'Sound Output Write.vi'.
Only make sure that the sounds you ouptut have been fully output before using the 'Clear'-VI, otherwise you'll hear only the first "bleep" of your waveforms...
Sebastian
Message Edited by SFK on 03-03-2008 09:33 AM
Message 13 of 13
(1,021 Views)
