Steps to write data into the DAQ Card using LabView
Can u please send any sample code or steps to be followed to write/read data into the DAQ card using LabView7.1?
Meenatchi
(3,506 Views)
Don't you have the LV examples. They give excellent example on how to do this.
André
André (CLA, CLED)
(3,497 Views)
Meenatchi,
There is a little bit more information needed to find the best examples for you; which card are you looking examples for (i.e. PCI-6251)? Which drivers are you using (DAQmx or Legacy)? But I will point you to my two favorite places to find examples: NI Developer Zone where you can just type in the search field what you want to do and the example finder that is installed with the drivers that you are using.  And take a look to this amazing article in DevZone; Learn 10 Functions in NI-DAQmx and Handle 80 Percent of Your Data Acquisition Applications.
I hope it helps
Jaime Hoffiz
Product Expert
(3,466 Views)
Meenatchi,
Just try out serching in the Functions pallette's Search dialog in the names of DAQ read & DAQ write, you ll find the simple VIs in tjhose names inside the DAQmx pallette.
Or you can find some very good examples in the Example Finder, which is in the menu Help -->> Find Examples.
- Partha ( CLD until Oct 2027 🙂 )
(3,449 Views)
