Stepper motor control through COM port using labView
I need to control the position, velocity and acceleration of 3 stepper motors simultaneously. So, I used a TinyG stepper motor driver board which takes G-code as input. I have connected the TinyG board to the COM port in my computer. I want to use LabView to write G-codes to the TinyG through the COM port. How do I go about this?
(4,050 Views)
Accepted by topic author nitm07
Hi nitm,
you use VISA functions to write your "G codes" to the COM port.
LabVIEW comes with a huge library of example VIs, there are also examples for serial port communication!
(4,035 Views)
Google "g-code LabVIEW" and you should get a lot of hits to other discussions about this topic. And as GerdW has mentioned, there are a lot of examples of COM port usage in LabVIEW.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(3,970 Views)
Thanks GerdW ! 🙂
(3,930 Views)
Cool 🙂
(3,929 Views)
I am trying to use TinyG driver port too. I have problem communicate with it via Labview. Would you mind sharing the program you wrote for tinyG?
Toan
(3,734 Views)
