Stepper Motor Speed Control
Since I'm the one who brought up the X-series boards, I'll take a shot at this.
- Yes, you'll definitely need to change your code.  Your old method used a software-timed digital task.  My reason for recommending the X-series is that it supports a much better method based on a hardware-timed counter task.
- Hardware timing for the *pulses* will be guaranteed by the use of a counter task.  Hardware timing for your *program* is another matter entirely, but I suspect you're mainly interested in the timing of the signals you generate.
-Kevin P
Message 11 of 11
(694 Views)
