Step signal simulation
Hi GerdW,
   Certainly. I will try that and let you know. Thanks!!
Best Regards,
Dhans 😉
Kudos are welcome 😉
Aspirant Labview Programmer (Labview 14) 😉
Message 11 of 19
(1,494 Views)
Hi GerdW,
   Here is another problem.Smiley Very Happy Waveform graph shows nothing even though I have attached a signal.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 12 of 19
(1,491 Views)
Hi Dhans,
I don't have the SimToolkit available nor do I know the functions used in there.
So I cannot comment on your graphs.
Why should the "Waveform graph" show "nothing" when the "UNLOAD WAVE" does show a signal?
I'm sure there is a signal in the graph too: I guess this function from DSC module will just convert your scalar value into a waveform consisting of just one sample. To see this one sample in the plot you need to change the plot properties (set it to show a point for each sample)!
Message 13 of 19
(1,483 Views)
Hi GerdW,
    Yes. I tried. But couldn't find that property. In fact, in an autoscale mode  of X and Y axis, graph seems moving bur can't see the waveform.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 14 of 19
(1,476 Views)
Hi GerdW,
   I have seen a single point in a graph after did what you have said in the last post.
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 15 of 19
(1,468 Views)
Hi GerdW,
    Here I have attached a file. I have used square wave function in labview to create step signal I need. I have done it. But when I run a program for more than one or two times using for loop, waveform shape has changed as in the attached image below. Why  is that?
ProgramProgramunwanted waveunwanted waverequiredrequired
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 16 of 19
(1,463 Views)
Accepted by topic author dhans
Hi dhans,
use all inputs of the signal generation function - as I did in my snippet...
Message 17 of 19
(1,459 Views)
Yeah, I did like that. isn't it? seems your snippet and my snippet looks like same? where is the error?
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 18 of 19
(1,456 Views)
Hi GerdW,
Thank you for the reply. I have missed a duty cycle input in the square wave generator. Now
I have added an input of 100 dbl to that input, i.e, 100% duty cycle. Now it works fine.Smiley HappySmiley Wink
Best Regards,
Dhans 😉
Kudos are welcome 😉
Message 19 of 19
(1,445 Views)
