Stellaris ICDI USB driver compatibility with Labview
Hi!
I have a compatibility issue between Stellaris ICDI USB drivers (on a Texas Instruments EK-TM4C1294XL developer kit) and Labview.  When I try to set the serial communication to 115200 baud I get a warning and it looks like the baud rate remains at 9600.  The following links discuss this issue:
Following suggestions from the above links, I was able to update the uController ICDI firmware to the latest version,
but still  experiencing the compatibility (baud rate setting) issue...
Thanks for your help!
Dar Bahatt
(3,791 Views)
Hi Dar,
I took a look at CAR #182027 in the NI database and it looks like it has been fixed in VISA 15.0.0.  What version of VISA are you using?
Pat
Applications Engineer | National Instruments
ni.com/support
(3,737 Views)
I'm using VISA ver 15.0.
See attached screenshot for MAX
When using the set serial port I get an error indicating that a property cannot be set
(3,734 Views)
Hi Dar,
Could you send me a screenshot of the error that you are getting?  Also, are you running LV code or are you doing this through MAX?  Either way please post a screenshot of how you're trying to connect.
(3,714 Views)
