09-24-2008 08:49 AM
09-25-2008 05:25 PM
Hi Heiko,
Can you post a screenshot of what you get when you try to set up the static URL mapping?
Ipshita C.
09-25-2008 06:50 PM - edited 09-25-2008 06:51 PM
I get an 'Routing template contains invalid syntax' error.
09-26-2008 04:48 PM
Hi hfettig,
The URL mapping action lets you 'refer' to a service name and the parameters you connect to within that service name. It does not map to a directory. The destination folder is where your strt page build is stored. Therefore, wehn you try to map an item that you think is a static folder, the mapper sees an invalid character which does not have any service associated with it. For more details on this please refer to the LabView Help Section of Web Services.Hope this helps.
Ipshita C.
