Static and dynamic reference
This VI reference is called static reference and property node reference is called dynamic reference.
Can I check this concept practically.
Anand
(7,607 Views)
Is there any reason calling "This VI" reference as static reference and property nodes are dynamic reference . Can I check this concept practically with some sample VI.
Anand
(7,612 Views)
Not all Property nodes are dynamic.  If you have a property node linked to a single control, without any Reference input at the top left, this is static.  If the property node is assigned an object on which to operate at run-time, then it is dynamic.
2018-04-19 17_31_52-Untitled 1 Block Diagram on V5 FPGA.lvproj_My Computer _.png
This is essentially the difference.
"This VI" is, by definition, static since it can only ever refer to a single specific object.
(7,606 Views)
Please don't create multiple posts for the same topic
(7,603 Views)
I have merged the threads to avoid some confusion.
(7,576 Views)
Hi ,
Thanks for merging those post.
@Intaris,
This VI reference  and other reference e.g. (property node or invoke node) are pointers. Can you see the address value of this pointers before running VI and when running VI. I need to check how stack , code space and data space allocation happens in Labview.
Anand
(7,554 Views)
References are 32-bit handles.  You can see the value of a reference by casting it to a U32.  However that number doesn't really tell you anything, it's just something that the RTE uses to access the object.
(7,512 Views)
