Static VI reference and Property Node Help
I am try to open a second VI that will serve as a instruction viewer from another VI. I have never done this before, but I have the code working my computer. I created this little attached  tester to verify the code. However when I send it to my client, embedding in his code, he says that the instruction viewer.vi (which is the called by his main VI) opens, but doesn't run. I cannot figure why this might be. Can anyone look over this code and tell me if there is anything that might cause the called vi to not run when called.
Doug Ferguson
(2,824 Views)
Try changing the inputs o the Run VI method.
Message Edited by Michael Aivaliotis on 05-18-2007 01:26 PM
Michael Aivaliotis
VI Shots LLC
(2,811 Views)
