State machine program for multichannel multi sample input
Hi to all,
            I have created a simple state machine program to acquire the data from DAQ 6211 device 16 channel input and used tare function to initialise a voltage to zero and now what i want it is?
i need to display a XY graph for all the 16 channels, and i have attached a model vi too for this vi and also at the same time i need to create a analog output channel also, how can i to do this all easily together, i will attach a vi together for better analysis.
Thanks in advance,
regards,
Dinesh
(2,896 Views)
Can you explain the part about creating an analog output channel? What difficulty are you running into?
As far as displaying the channels on a graph, you can use something like the "visible" property. (I actually used a chart in this example).
(2,854 Views)
Hi gregoryj,
             Actually i need to do this for xy graph same thing you've used for waveform chart in the vi you send me and also i need to do it for all the 16 graph for each and every channel i need same user selection window, if you go through the example.vi that i have uploaded here once again you can understand what i want and also i have attached one more model vi to understand what i want? i have used NI usb 6211 to acquire the signals here same like i want to do in the state machine program, so i want know what i have to do and dont's here?
Anyway, thanks in advance,
Dinesh
(2,813 Views)
