11-28-2020 09:34 PM
I have a program where I would like one of the events to start when a pre-determined elapsed time has gone by. I tried to trigger the event with a boolean: Elapsed time = given value is true, then go to that event. However I cannot get it to work. I am attaching the code but just in case it does not open, I am also attaching a picture of the relevant portion in the block diagram. Any advise?
Solved! Go to Solution.
11-29-2020 03:49 AM
To trigger the event structure you have to use a value signaling property node, not the terminal nor a local variable.
11-29-2020 09:09 AM - edited 11-29-2020 09:14 AM
Kudos for a link to my tag Grandmas house thread!
Extra kudos if you post the small child in the back seat as a dynamic event!
@OP, you have to break the data dependency between the parallel loops!
12-02-2020 10:26 AM
Thank you so much! That worked!
