Startup executable run continuosly
Hi all,
is it possible to set a startup executable ton PXI-8100 real target in "Run continuosly" mode?
(3,957 Views)
HI,
Use a  loop 🙂
Regards
Sabri JATLAOUI - Certified LabVIEW Architect - Certified LabVIEW Developer
(3,940 Views)
This is what Sabri means ...
(3,936 Views)
(3,917 Views)
As a general rule, you should never use the Run Continuously mode, except for specific debug situations.  Using it often means you are constantly opening and closing resources, which should only be done once, PERIOD.
(3,906 Views)
