Starting For Loop (Boolean)
I would like to start a particular loop in labview after the user makes an indication (using an on/off switch or button for example). So the program will run and when the user hits "on" the program will continue and  complete. I tried using a boolean control at the beginning of the loop, but I am not getting any understandable result...pleeease help...thanks
(3,298 Views)
You just need a case statement with the for loop inside. You should really try to take some basic LabVIEW courses. There are a couple at http://www.ni.com/academic/lv_training/how_learn_lv.htm.
Message Edited by Dennis Knutson on 04-16-2007 03:05 PM
(3,283 Views)
