08-22-2021 04:08 AM
Hello Bob,
I tested the application node method, and this is exactly what I need to distinguish between the development and runtime environment. Thanks for you very comprehensive reply and explanations. Very simple.
Now my NI-Server approach to start AND end a sub-vi from the main-vi becomes more promising than the notifier/queue method I am trying to get on with (with little progress).
Thanks, and have a great weekend!
Ralf
08-22-2021 06:56 AM
Hi Gerd,
looking into queues and/or notifiers there seems to be only one possibility - as you said - starting the sub-vi with the main-vi and calling the FP and other things from the sub vi using notifiers. Not really what I was looking for, but with the loop issue this seems to be necessary. Strangely, my NI-Server approach with just closing the sub vi works well. But I agree, this is far away from how it's supposed to be from a programming point of view.
I have modified the Main/sub VIs, and it works apart from one thing.
When stopping the main loop (Stop button) closing the vi takes forever. It seems that, although I can't see any reason, the lower loop runs into a timeout or anything else.
I have attached the files. Maybe anybody has an idea why.
Best Regards
Ralf
08-22-2021 08:23 AM - edited 08-22-2021 08:30 AM
Hi Ralf,
Because you are doing all this much too complicated!
And you don't stop the subVI when you press the stopp button in your mainVI! You just close the frontpanel, which will not stop execution of the subVI…
Just cleaning up your VIs:
Notice the subtle changes I made! (No shift registers in the subVI, feedback nodes in the mainVI, small wait in the lower loop,…)
I recommend to use just one (1) queue to send commands from main to subVI: why do you need 3 boolean notifiers when you can do all this using just one queue sending a typedefined enum command?
Btw.
08-23-2021 04:02 AM - edited 08-23-2021 04:09 AM
Hello Ralf,
did you have a look at the examples I gave you the link to?
Based on that (Splash Window) example I adapted the VIs. Now they show you an example how to solve your problem with a QMH (using events), passing data from the main-VI to the sub-VI and controlling the behaviour of the sub-VI exclusively from the main-VI.
P.S. Another hint: use the "Highlight Execution"- button from the toolbar of your VIs block diagam. You can open both BDs (of main- & sub-VI), click on the bulb and start the main-VI. This (and some patience) will give you an impression, how this works.
08-23-2021 07:09 AM
Hello Gerd,
as suggested I have reduced the notifiers to just one - openFP+activate and closeFP. Whenever the FP of the sub-vi closes the motorcontrol goes offline before. This works.
Howver, now I have ran into another issue.
The sub-vi is basically also a sub-sub-vi and is used in the main-vi and several sub-vi. Let's call it contro-vi.
I can use the control-vi in a sub-vi of the main-vi as intended. However, whenever I try to end the sub-vi to go back to the main-vi it keeps running and is waiting for the control-vi to finish/end.
I can't end the control-vi because I couldn't use it anymore, and closing the FP of the sub-vi doesn't seem to be enough. Just closing the FP of the sub-vi doesn't work, too...because everything is waiting for the control-vi to finish/close.
At the moment I don't see any other way than going back to the ServerVI method and open/close the control-vi whenever it's required.
Any idea/hint how to close the sub-vi and getting back to the main-vi would be really, really appreciated.
Grrrrrrr, this is driving me crazy.
Best Regards
Ralf
08-23-2021 09:51 AM
Okay, it is/was quite obvious with the sub-vi in a sub-vi.
I must not open the control-vi again, but dragging the notifier all along to each sub-vi.
My head is spinning.
Ralf
