Start, Stop, Step array builder
I would like to enter the start, stop, and step frequency to build an array that will hold the value's to feed to a sweep generator.
I have something that works, except for one thing; the stop value. I can't seem to get this thing to stop on the stop frequency value. The step value seems to affect this too. So could anyone take a look at my vi, and help me with this? also, the code looks a little complex for what might seem like a simple thing to do.
Message 1 of 8
(7,504 Views)
Unfortunately, I do not have LV 9, but perhaps you are trying to do a equal test on a double?  If so, try using a test that uses a <=, >=, < or > operator.
A
Message 2 of 8
(7,498 Views)
No need to make your own! Use the ramp pattern with option "ramp by delta".
Your code is way too complicated anyway. At least you need to insert a "+1" before wiring to N.
Message 3 of 8
(7,489 Views)
Accepted by topic author Rivetm
Anyway, here's a slightly simpler implementation of your code. As you can see, you codes was way more complicated than needed! 😄
Shown below is the ramp pattern implementation (recommended). Both give the same result for sane inputs.
I would definitely use the ramp pattern, because it has better error handling (e.g. if the delta is zero or max is +Inf, etc.).
You can look at the code of it to learn something. 😉
You need to be a bit careful with possible accumulations of binary errors, especially with fractional steps that cannot be fully represented in binary (e.g. 0.1)
Message 4 of 8
(7,477 Views)
All I can say is "wow". That's good stuff. I knew that my code was clumsy, for sure. But I just couldn't get myself out of it. You have shown me how to improve on my own idea, and also shown me something I have never seen before. I cannot thank you enough.
Message 5 of 8
(7,457 Views)
Wouldn't it be nice if we had a For Loop option to set Start, Stop, and Step?  Just like in any other programming language?
- tbob
Inventor of the WORM Global
Message 6 of 8
(7,450 Views)
You mean like this?
Message 7 of 8
(7,434 Views)
@altenbach wrote:
You mean like this?
Yes!  It would be nice if more people would Kudo the idea.  This feature is long overdue.
- tbob
Message 8 of 8
(7,409 Views)
