Start FOR loop from specified iteration number
That is Replace Array Subset.  Expanded for two dimensions.
Lynn
Message 11 of 14
(882 Views)
I love this forum!!!
Message 12 of 14
(878 Views)
@NapDynamite wrote:
Have you used Replace array or Insert Into Array inside the second loop?
There two are very different functions and it is very important that you learn the difference:
  • "replace array subset" keeps the array at the same size and places new values in designated elements. This is very efficient because no new memory is allocated.
  • "Insert into array" will insert an element at the designated location and move all higher indexed elements up a slot. The array size grows! Not only does new memory need to be allocated, but many elements need to change their index. This can be orders of magnitude slower.
NapDynamite wrote:
Can you please send me this VI? 😞
Were you able to recerate the functional VI from the image?
Message 13 of 14
(875 Views)
Yes I was able to draw the VI. Thanks alot for your help. 😄
Message 14 of 14
(870 Views)
