Start Asynchrounous Call if not already running
One thing I should point out is that a running vi in LabVIEW that is waiting on something, like a Queue or Semaphore or whatever, isn't actually occupying a thread or using any CPU.  Memory is different, as LabVIEW tries to reuse memory, and you have to do more than stop a vi to release memory.
Message 11 of 15
(670 Views)
If it's a non-reentrant VI, what's stopping you from writing to a global variable when the VI gets called and again when it stops. Call the Global "Running" and write to it appropriately. T when starting, F when stopping.
The global will then tell you pretty easily if the code is running or not.
I can't think of a more simply way to do it tbh.
Message 12 of 15
(662 Views)
Frankly,  I would just let the subvi go idle and stick an Event loop on top of it.  Let it respond to dynamic Events like "Execute", "Quit" or "Abort(enqueued other end)"
"Should be" isn't "Is" -Jay
Message 13 of 15
(635 Views)
I mean, what I don't get is:
If your calibration is already running, why would your program want to start another calibration? Your program seems to have some issues with communication. Why is the previous call valid and the new one is not?
If the new one is not valid, why call the calibration at all?
What's wrong with queuing up a second run?
So many questions.
Message 14 of 15
(604 Views)
I've used this approach in the past, but you need a separate globale variable for each windows, which gets annoying quite quickly.
Instead I use the "FindWindowA" method from the user32.dll to find if the window is already open, if not launch it. If yes, bring to the front (or do whatever). It is my standard template for launching any asynchronous window that has only 1 instance.
Example above is attached (LV2018)
I guess the only downside is that you cannot change the window title dynamically. In that case, use the global variable approach I guess.
Message 15 of 15
(588 Views)
