Stand Alone Control
Hello.  I am completely new so this may be a very easy question:
All of the code works as expected.  My issue is this:  I need abput 50 sets of these controls (two pressure indicators and one tank level indicator plus all of the logic).  I want all 50 to be controlled by the two knobs and the one stop button.  Is there a clutter free way of doing this... in VB.NET I would simply create a control and have three inputs (two doubles and a boolean).
Thank you in advance for any ideas!
Message 1 of 16
(4,585 Views)
Hi seascan,
what you call "control in VB.net" is named VI in LabVIEW - yes you can create one with 2 inputs and one output...
And when you need 50 of them: consider using arrays for your data - and please go through this!
Btw. don't you think it's a bit of overkill to calc gain/offset with fitting routines?
Message 2 of 16
(4,577 Views)
Hi GerdW.  I have been through all of those over the last two days.
Perhaps I've missed something, but I can't figure out how to add my VI (below)
to a project and see the GUI.  You can see that the upper right corner show the two doubles and the one boolean wired correctly.
Message 3 of 16
(4,562 Views)
Forgot to ask:  besides using the fit function or doing the raw math, is there a built in function for scaling a sensor?
Message 4 of 16
(4,559 Views)
You could use the slope and offset in the DAQMX channels. This way everything is scaled prior to using it in your code.
Tim
GHSP
Message 5 of 16
(4,552 Views)
So if I understand you correctly you need to have fifty seperate controls for different tanks correct? How do you expect to do this without having this be cluttered?
Tim
GHSP
Message 6 of 16
(4,551 Views)
How do you plan on this code working? What is the flow that you expect?
Turn two knobs to desired level
Read sensor
Adjust output
Tim
GHSP
Message 7 of 16
(4,550 Views)
Hi Tim.  Yes, basically that is it.  For now I want to knob controls (4-20) to be inputs to all 50 "controls" or VIs.  Later after everything is working I can plug in an actual DAQ and use real data.  For now, two knobs and one stop button to control all 50.
The GUI will be cluttered!  But I was hoping to not have to copy and paste all the logic -- I thought perhaps a cluster would work but I can't seem to add the logic to a cluster (I guess it is only a container).
Here is a project I made that contains my VI.  This is great EXCEPT I can't see the VI's Front Panel in the new VI.
Message 8 of 16
(4,541 Views)
Make a sub VI and have the two controls be references into each instance. That way you make the code once and connect the same knobs to the all of the vi's
Tim
GHSP
Message 9 of 16
(4,533 Views)
Tim,
That is exactly what I want to do but when I try to create the subVI, it bundles everything except the visual controls.  Is there a way to create a subVI with the associated visuals?  Here are the before and after screen grabs:
AFTER:
Message 10 of 16
(4,512 Views)
