Stacked String Indicators
Is there any way to display the contents of a string stacked.  For example, my string changes with respect to the key press by the user, however I like the information transformed from horizontal to vertical.
i.e.  Instead of having "string" horizontally, I want to display s
        t
        r
i
n
g
(3,050 Views)
See if this helps.
Matt
Matthew Fitzsimons
Certified LabVIEW Architect
LabVIEW 6.1 ... 2013, LVOOP, GOOP, TestStand, DAQ, and Vison
(3,040 Views)
By default, string indicators autowrap. You could just resize the string indicator so it wraps after each character (see LV 7.0 example. You might need to resize the indicator slightly depending on your font settings).
(3,019 Views)
The best solution is always the simple solution.  Smiley Surprised  Use the resize text box method.
Matt
Matthew Fitzsimons
(3,004 Views)
