Srvr.ServiceName does not register with NI Service Locator
I have an app that sets it own Service Name. It works when run from the development environment and I can verify that the NI Service Locator
captured the new registration. If I build an exe the new Service Name does not get registered. Any Ideas? Thanks.
(2,660 Views)
Hi sachsm,
How are you setting the Service Name of your app?
(2,641 Views)
I am trying to use the srvr.ServiceName Property.  I am thinking that my problem may stem from the application refnum that has this property.
From the development environment this is the main app refnum but from a exe built from a project I am getting the app refnum by using the vi
property called OwningApp. But unfortunately this does not seem to work and I do not know why.  The only technique so far to work is to
use the create tcpip listener function.  This registers any ServiceName you give it and it also works inside an exe.  The only problem is that I do not
really want to create such a listener.  I only want to have each exe instance (Yes I am planning on having 3 or 4 instances of the same exe running on a single machine) to be able to have its own viserver ServiceName.
(2,637 Views)
is it possible for you to post an example of what you are trying to do?
(2,622 Views)
