Spurious signals in PXIe 5641R IF transceiver
Hi all,
I am using the example named 'RFSG Single Tone Generation.vi' to generate a signal from the RF signal generator and give its output to PXIe 5641R IF transceiver. And then using the FPGA example named 'Analog Input' for PXIe 5641R IF transceiver, i tried to view the spectrum of the generated signal. The spectrum shows some spurious signals that disappear with the reduction in signal span. I have tried it with different Signal Span options and the results are shown in the files attached. I am getting these spurious signals even if i don't give any input to the IF transceiver.
Any ideas why is this so?
(2,441 Views)
Sandee,
Those look like harmonics (except for the DC componnent). The second harmonic is down >30 dB from the fundamental.
What are the specifications of the signal generator at this frequency and power output level?
Lynn
(2,434 Views)
The center frequency of the generated signal was 2MHz and power level was -30dBm.
I have attached another image that shows the results when there is no input connected to AI port of PXIe 5641R. I get this peak of a very high level at the specified AI center frequency.
(2,427 Views)
Does you signal have a DC component?  This can produce large zero-frequency results in the spectral analysis.
What is the harmonic output specification of your signal generator hardware?
Lynn
(2,423 Views)
