Splitting up an array
Fairly simple task, but too early in the morning / late in the week....  usual excuses.
I have a large array of samples (let's call it array X) that I want to split up into several smaller arrays.  I have a second array (let's call it array Y) that contains the indeces to where I would like the splits to occur in the array X.  These indeces will always be in ascending order.
Furthermore, I need to delete the +/-5 elements in array X either side of where the split happens.  So, for each split defined in array Y, I want to delete 11 elements in array X, as well as perform the split.
Once the splits and deletions have occurred, I would like to pack the resulting fragments of array X into a 2D array.
If there are no splits (i.e. array Y is empty), then I simply repack the original array X as a 2D array with one of the dimensions equal to 1.  This is shown in the attached "no_splits.png".
If there is one split, then I perform the split and deletion as described above and pack the resulting 2 parts of array X into a 2D array.  This is shown in the attached "1_split.png".
In the attached PNGs, the integer array is array Y and the 1D double array is array X.
My issue occurs when there are N splits.  Clearly I need to use a FOR loop, and perform the split and deletion routine N times, feeding back the remaining part of array X each time.  However, I can't for the life of me get this to work - clearly I need to compensate for the offset incurred by the deletion of each successive portion of array X when using the values in array Y to index the next split location.
Any suggestions welcome.  Let me know if more clarification is needed.
Dan
Dan
CLD
(3,515 Views)
How about something like this.
Note that the columns in the resulting 2D array get padded with 0s if the splits are not the same length. Also, if a split occurs within 5 points of the preceding split the whole column is padded with 0's.
Dave
Edit: replaced attached vi.
Message Edited by DavidU on 09-03-2009 11:51 AM
(3,491 Views)
just noticed that my original vi only removes 4 points from the start of each split becasue I didn't take into account the split point itself. I've fixed this in the attached vi by adding a +1 primitive in the loop.
Dave
(3,465 Views)
