Splitting CAN frame
Hi there!
Im Using the "CAN frame Input Single Point" example VI (from NI XNET examples) to read a CAN frame from a ECU. It works fine. My question is, does anyone knows how to split this result into que various values that a CAN frame contains? Here is a VI with the reading I get. I need to split the marked part on the image attached.
Fernando H. Moreno
(2,382 Views)
did you mean that ?
V-F
(2,368 Views)
