Split string at offset into two substrings
Hi
I have got a string that I want to split up into two substrings kinda like the vi Search/Split String, except that I just want to split it at a given offset without using the search function, how can I do this?
Best regards
Simon
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(4,421 Views)
Hi Simon,
use "Search/Split String" without wiring a search string... And read the context help for this function!
Message Edited by GerdW on 02-28-2008 03:25 PM
(4,417 Views)
The online help indicates that if you leave the string/search char unwired, it will split the string at offset.
(4,415 Views)
Hi Gerd
Thanks it worked. I didn't see in the help that it could be done without the search term and only using the offset.
Thanks again
Best regards
Simon
VBAI 3.6 / 2010
(4,404 Views)
