Spilt 1d array
I have a 1D array that goes from 0-1024
How can I slipt it in half, so that I can do different things with the 0-512 and 512-1024?
I tried using the greater/less then but the output is a true false rather than the data
Thanks!
(2,539 Views)
Have you tried using the Split 1D Array?  It's in the Array palette.  I'm thinking the index to split at will be the N/2-1 (where N is the array size).
(2,537 Views)
