Speed Sensor Acquisition and Measurements
Hello guys,
I'm working on a testbench for traction motors. The goal is to make an automatic test sequence. At the moment, I don't have any problem with making a sequence.
When I try to make the acquisition of the speed sensor signals. It's typically 2 square signals phase shifted. On these 2 signals, I need to measure the phase shift (in time) and the overlap (in time). A draft (Capture.PNG) is attached to this topic to illustrate what I'm talking about.
So, I developed a VI using 2 simulated signals shifted and I succeed making the calculations I described above. Perfect!
The problem is when I use the real signals (acquired by AssistantDAQ) as inputs, the VI doesn't work anymore. The values are completely false. I don't understand why because both signals look clean on a graph but I do have some doubts about the acquisition.
I use a NI-9220 to read both signals.
- Acquisition mode: Continuous samples
- Samples to read: 3.5K
- Rate (Hz): 35 KHz
I would be super grateful if anyone can help me.
Nice day,
Damien
(2,595 Views)
Hi Damien,
Do you only have access to a 9220?
Otherwise I advise you to use counter acquisition with edge detection on your signal.
Here is a link to help you on that way : https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9qCSAS
Antoine
(2,560 Views)
Hello Antoine,
Thank you for your reply.
After reading the article you adviced me, I think that I need to buy a NI-9204 or NI-9435.
Then, I can measure :
- Pulse width
- Two-Signal Edge Separation
What do you think?
Damien
(2,511 Views)
