Specfifc IP Address configure control box
Is there any specific control to enter the IP Address in labview??
Please let me know.
S Nagaraju
Message 1 of 18
(7,375 Views)
No, in LabVIEW there is no ready-to-use control to input IP addresses.
But you can easily make your own (using a string input) or search for VIs/XControls in the forum. I'm pretty sure someone else already made such inputs…
Message 2 of 18
(7,364 Views)
Dear GerdW,
If i use string control I am not able to limit 8-bit number for each portion of IP Address and it also accepts the characters and special characters also.
I just want to avoid those conditions.
S Nagaraju
Message 3 of 18
(7,346 Views)
Hi Sonti,
you can use en event structure to filter unwanted chars when the user enters them. You can even program some more checks to allow just regular IP addresses…
Message 4 of 18
(7,330 Views)
Why don't you use 4 numeric controls? That's how the address is set in Windows.
Message 5 of 18
(7,312 Views)
Thank you very much  GerdW,
I will try this.
S Nagaraju
Message 6 of 18
(7,303 Views)
Dear Dennis,
We can use 4 numeric controls also, but only thing is cursor automatically move after entering 3 digits in each control.
S Nagaraju
Message 7 of 18
(7,295 Views)
That can be accomplished with a set focus property node in the value change event for each control.
Message 8 of 18
(7,277 Views)
I use a string control and error check it like this:
=== Engineer Ambiguously ===
Message 9 of 18
(7,257 Views)
As already pointed out:
@GerdW wrote:
...or search for VIs/XControls in the forum. I'm pretty sure someone else already made such inputs…
https://lavag.org/files/file/36-pta-ip-address/
There are probably others too.
___________________
Try to take over the world!
Message 10 of 18
(7,245 Views)
