Source code to control number of points
I am using agilent 4195A with LAbview 7.1. i searched the manuel of the book but i was not able to locate the command code used to control the number of points that i want to set. And also, how am i able to combine a few graphs together after performing a for loop?
thank you
(2,449 Views)
Hello tyl,
I am not familiar with your instrument - it may be best for you to call Agilent to get that information.  Are you using an IVI driver from www.ni.com/idnet?  That may help you work around the command code issue.
To combine multiple plots together, you can just use the merge signals node, which is found under the Express >> Signal Manipulation palette.
Good luck!
Janell R | applications engineer
(2,426 Views)
