Source Control query
Hi all
I've been using LabVIEW internall SCC for a while and it's been great. However I have a problem now. I have about 6 versions of a code source-safed. I want to retrieve an older version to modify but it doesn't allow me to do that. Whenever I retrieve a older version, it is in READ-only mode and I am not able to modify it at all. Can someone help me on this ?
Sridhar.
(2,645 Views)
After you get the older version saved to disk, use Windows Explorer to bring up the properties of the file and uncheck the "read-only" box.
(2,628 Views)
That doesn't work. I figured it out. The files are internally locked out. So we need to goto Operate-->Change to edit mode and it works.
(2,615 Views)
