Source Control on LabVIEW???
How can we control on the version of VI? For instance: we have "FileName.vi" version 3 and we want use "FileName.vi" with version 1 or 2.1. So how can we get that version for "FileName.vi"? And I've received error msg when go to Tools - Source Code Control and the msg is as attachment.
Please help
Thanks alot
(2,987 Views)
This is definitely something you need to take up with NI support. Go to http://ni.com/ask to get started.
Good luck
(2,987 Views)
If the SCC Administrator has enabled backups, then you can retrieve previous versions of a VI by going to Source Code Control >> Advanced >> View File History or View System History. Page 11-26 of the Professional
G Manual has some more info on this:
http://digital.ni.com/manuals.nsf/websearch/57CC60D27B73A6FB8625665E00635940?OpenDocument&node=132100_US
I looked at the screen shots you sent and they reference the 'provider dir' and 'working dir'. Have you gone through Source Code Control >> Administration... to configure the SCC system?
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,987 Views)
