Source Control Error 25581
LabView 7, VSS 5.0, eror 25581, Win 98. Source Safe worked with version 6.1. I used an error cluster to find what 25581 is - and it came up with a bogus result "Error undefined.". When trying to connect to VSS error 25581 states "Visual Source Safe does not appear to be installed." Is there a fix? Is there a work-around to use VSS w/LabView 7.0?
(2,744 Views)
Found the answer myself:
http://digital.ni.com/public.nsf/3efedde4322fef19862567740067f3cc/ca6cd31f906b4e4d86256d3300590fbf?OpenDocument
It took over 90mins, should have been a lot less. I should have been able to search for Error Code 25581.
(2,744 Views)
