Source Control Check In Error
I have just had Team Foundation Server setup to work with LabView Source Control and the checkout and compare functions are working fine. When I try to check a file back in from inside LabView I get an error of "Value cannot be null. Parameter name: path1".  If anyone can help with this it would be greatly appreciated.
Mike
(2,543 Views)
By "LabVIEW Source Control", do you mean Source Control integrated with LabVIEW (on the Tools Menu under Source Control)?  I've been using Subversion's Tortoise SVN for about a decade, and have always used it "outside" the LabVIEW Environment (usually from Windows Explorer).  There are several Tools on the LabVIEW Tools Network (I'm thinking of Viewpoint System's TSVN Toolkit) that give you access to Tortoise SVN from within the LabVIEW environment, but I don't know Team Foundation's Version Control product.
(2,526 Views)
