Source Build with type def controls
I have a project that has several type def'd controls.  When I try to do a source code build - it fails because the builder tells me the files can't be found - even though it is searching for the files EXACTLY where they are located.  If I select Disconnect type definitions...  in the distribution settings, the build completes - but the controls are not included in the build.  This happens even if I set the settings for these files to "Always Include".  I am using LV 8.  Is this a known issue?
TIA,
Bill F
(2,523 Views)
Hi, Bill,
Hmmm, strange, for me it seems to be OK. Typedef Always included and not disconnected, and builder works without any problem. See attachment.
regards,
Andrey.
(2,509 Views)
