Sound source localize
hi! I'm doing a project to localize acoustic source with array of hydrophones
From where should i begin?
What is the hardware should i use?
Message 1 of 17
(6,496 Views)
Type of sound source? This define your needed frequency range, so the needed samplerate (I would go for 5 to 10 times max freq)
Number of Hydrophones? That defines the number of channels you need
You should look for simoultanious sampling devices, for a lot of sensors you need to be able to sync them.
Signal processing:
What signal processing way do you want to go?
(single pulse signals -> simple correlation, tone = FFT phase?)  Lot of papers and web sources to read..
'Real time' ?  How fast do you need to localize?   Than will give you an idea of the DSP power you need. (FPGA?)
For your first steps you can use two simple mics and your soundcard 😉
Greetings from Germany
Henrik
LV since v3.1
Message 2 of 17
(6,454 Views)
Signal processing:
Message 3 of 17
(6,446 Views)
@MohamedOsama wrote:
Yes.  You need to learn several things:
  • The "physics" of sound and sound propagation/transmission.
  • Something about the nature of signals, signal measurement, signal analysis.
  • Principles of data acquisition, including effects of sampling, digitization, analog/digital representations.
  • If you want to do the acquisition and analysis in LabVIEW, you need to learn (and get experience) in LabVIEW.
These things take time, of course, but if you put in the time, you'll be able to do these, yourself, and for others.  Otherwise, there are engineers and scientists whom you could hire to do it for you.
Message 4 of 17
(6,441 Views)
how can implement array of microphones to labview with myrio ?
Message 5 of 17
(6,460 Views)
How would you implement 1 microphone?
How would you implement 2?
An "array" is going to be just like 2, but more.
Your question lacks any details of where you are having problems to be able to offer any more specific help.
Message 6 of 17
(6,432 Views)
I should implement 3 hydrophones and take an output of each one to a band pass filter then compute the phase shift between them
Message 7 of 17
(6,393 Views)
Have you been able to connect 1 hydrophone  and get signals from it?
Message 8 of 17
(6,383 Views)
No, at least 2 hydrophones
Message 9 of 17
(6,380 Views)
Until you figure out how to connect 1 hydrophone, you shouldn't be thinking about 2 or more hydrophones.  How should they connect to the MyRIO?  Do they output a voltage signal?  I'm not familiar with the MyRIO, but I assume it has analog input channels.
Message 10 of 17
(6,376 Views)
