10-31-2019 06:02 AM
Hi
Good day.
I am beginner to LabVIEW software and recently working with LabVIEW 2017 for data acquisition.
I have to acquire respiratory sound signals continuously using a digital stethoscope connected to PC via audio jack. I need to perform multiple recordings in one acquisition, so I added a waveform chart into the vi for continuous acquisition and write to measurement file for saving data of multiple recordings.
I need to acquire sound signals at lower number of samples (such as 100Hz). When I change the number of samples from 10000 to 100, it showing some errors.
How could I acquire the sound signals at lower number of samples? Could anyone guide me on this?
Attached here is the vi responsible for sound acquisition and errors shown.
Thanks.
Priya
10-31-2019
07:02 AM
- last edited on
05-14-2025
01:44 PM
by
Content Cleaner
You are likely overrunning your read buffer. You really should separate your acquisition and outputs. Do this by using a Producer/Consumer. The idea is to have your acquisition in a single loop and use a queue to send the data to another loop that can then write the sound out and/or write the data to a file.
