Sound and vibration assistant crash
I've set up a project for calculating the zoom spectrum for some vibration data. Now the Sound and vibration Assistant crashes as soon as the project is fully loaded. Why? Is the project file damaged?
This is not the first time this happens so I usually take backups of the project files before changing anything. But unfortunately not this time.
I think the Assistant is a great tool for quickly setting up measurements and performing analyses BUT it has some major stability and memory handling issues. Smiley Sad
(2,586 Views)
Hi Jocke
I downloaded your project and I have no problems opening it. Which version of S&V Assistant are you using?
Best Regards
David
NISW
(2,558 Views)
I'm using the latest version, 9.0.0.
Fortunately the problem was solved after I restarted the S&V Assistant three times.
(2,554 Views)
Hi Jocke
Sounds a little wierd. If you keep having problems with the software it may be an idea to uninstall and then reinstall it. It shouldn't crash and be that unstable.
Best Regards
David
(2,548 Views)
