Sorting array based on topic name
I have two data sets being continuously streamed through an mqtt server, RX topic and RX message. I need my final output to be a 1x22 array the RX message and the corresponding RX topic (22 channels)
here is what i have no far. It works for checking if the topic name is the corresponding channel, then outputs the corresponding mesasage.
My question is there definitely has to be a better way to do this than pasting the same loop 22 times and then building the final array
(3,733 Views)
By pasting 22 times you mean the only thing changing in the loop is the string equal going along a pattern like this
daq/1/ -> daq/2/ -> .... -> daq/21/ -? daq/22/
And that's how you'd get all 22 channels by just changing that 1 number in each loop?
(3,716 Views)
Accepted by topic author arob
I'm guessing you are looking for something like this SubVI. Note that the input array has be initialized (i.e. have size 22), as well as the array with channel names.
(3,710 Views)
yes perfect thanks
(3,678 Views)
