Sorting a Table
Both methods have problems sorting numbers that have differing numbers of digits past the decimal point. For example, 10.425 becomes 10.000000425, while 10.422425 becomes 10.0000422425. That I can control easily by formatting any numbers with a fixed number of decimal places.
But both methods also have trouble with negative numbers, and I haven't figured out how to fix that yet...
Message 21 of 36
(1,654 Views)
I never considered supporting fractional numbers.  (But I might start thinking about it.)
Message 22 of 36
(1,649 Views)
It is not expected to work with floating point numbers, but that can be solved once we know what's allowed.
Can we assume that your floating point fields don't have any alphabetic characters, or can they also be "mixed" (e.g. "10.456OHM" , "ABC=1.456", etc. "R.45AX:, etc.) Of course if they have an "E", they might be in exponential format.
Note that my sorting is most useful for filenames, mirroring the default behavior of windows explorer (e.g. file names have other periods, delimiting the file extension, so you need to be careful.)
Message 23 of 36
(1,643 Views)
If we can assume that floating point numbers are cleanly formatted, here's what you could do:
Basically, we check if scanning the fields as floating point gives no error or no remaining string. Please test! No guarantees. Works fine with negative numbers, integers, and floating point in any recognized format.
See below for even simpler code...
Message 24 of 36
(1,640 Views)
@altenbach wrote:
Yes, I got the gist of it from the picture
You are padding with spaces (i.e. a non-numeric character) while I am padding with zeroes (i.e. a numeric character)..
I am curious if there could be edge cases where it would make a difference, but haven't explored that.
One simplification would be to use the upper input of the format, eliminating your inner concatenation.
I briefly thought about space vs zero, but quickly convinced myself that it would be OK.
Message 25 of 36
(1,635 Views)
Accepted by topic author FlatCat
It's probably sufficient just to check for error and switch mode when an error occurs:
You might want to implement some error handling to ensure that all fields were processed with the same algorithm. (not shown).
Message 26 of 36
(1,622 Views)
This works. But, as I mentioned a few comments back when I described my first solution, I actually know beforehand whether the chosen column contains purely numeric or alphanumeric data. So I can chose the method on that basis. But the error check is nice if I just want to go by the contents of the table itself.
Message 27 of 36
(1,609 Views)
Try this.  Works with floats, scientifics, arbitrary number width.
Message 28 of 36
(1,573 Views)
Does not seem to work right with negative floats and thinks that negative numbers are largest.
Message 29 of 36
(1,532 Views)
The version I did yesterday seems to work better.
Also works correctly with +inf, -inf, NaN, etc.
Message 30 of 36
(1,529 Views)
