Sort array doesn't seem to work on an array of paths when <Not A Path> is involved
See the simple VI attached with default values.  I'm using 2011 sp1.  Is anyone using a later version of LV that behaves differently?  Am I missing something sensible that dictates that <Not A Path>s should be stuck in the same position in the sorted array?!  Even more strange, when I add another empty path to the end of the array, they start to sort (kind of).
Insight would be helpful.
CLA, CTA
Not my tempo... AGAIN!
(3,262 Views)
Accepted by topic author GarryG
It seems to behave correctly in LV2012.
empty path
C:\
asdf
some other path
<Not A Path>
<Not A Path>
(3,254 Views)
Wow!  Awesome.  Unfortunately, we have lots and lots of LabVIEW licenses where I work, so moving forward a version happens once every few years.  One more reason to push for it to happen.  Thanks for checking this!
CLA, CTA
(3,246 Views)
Or you can perform your own sort, where the Not A Paths are placed where you want.  Attached is an update to your VI where it will find the Not A Paths, then remove them, then sort, then add them back.
(3,192 Views)
Thanks Hooovahh!
I appreciate the fixed version, and it's always interesting to see various workarounds.  The problem I'm attacking in a larger sense is finding the unique elements in an array in the most efficient manner (see other threads).  Because of this, having sort Array handle things by itself is critical to the efficiency of a specific scheme (you can use sort to eliminate a nested loop).
CLA, CTA
(3,185 Views)
