Sort a string into an array HELP
@Pazmush wrote:
What is the fuction you are using and is that a better way of doing it?
Also can anyone help with the table thingy problem?
The first function is Search and Replace String.  "N" is the search part, and the default for replace is a blank, so no need to wire anything there.  The second function is Spreadsheet String to Array.
Any method Altenbach posts is better than anyone else's.
What tabel thingy problem?
- tbob
Inventor of the WORM Global
Message 21 of 28
(1,914 Views)
you know....  the table thingy!  LOL!  😄
Message 22 of 28
(1,893 Views)
Mon cousin du nord, tu es dans une humeur joviale ce matin (ou apres midi), n'est pas?
- tbob
Message 23 of 28
(1,885 Views)
If faut bien..  Il fait 86deg F (97degF avec l'humidite).
Message 24 of 28
(1,876 Views)
Un peu froid eh?  Il fait 117deg F ici...  dans l'ombre Smiley Surprised
- tbob
Message 25 of 28
(1,869 Views)
Is it too late to jump in here and say:
To learn more about LabVIEW it is recommended that you go through the tutorial(s) and look over the material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
Or is that just wasted breath?
Message 26 of 28
(1,860 Views)
To simplify parsing of such "dirty" spreadsheet strings in the future, I posted an idea. See if you like it! 😄
Message 27 of 28
(1,856 Views)
It's never too late.
Message 28 of 28
(1,820 Views)
