Some issue when create exe
hello everyone I had created a project and it can be running successfully in compile environment. But when i create a exe, it can’t running. I used some vis of ZeroMQ ,and i have add dlls to my project. The error is as follows: Error 13 occurred at Call Library Function Node in zeromq.lvlib:zmq_context.lvclass:zmq_ctx_create.vi:5610006->RunStep.vi:4260001->Executor.lvlib:Executor.lvclass:Execute.vi:6020001->Executor.lvlib:Executor.lvclass:Execute test vi.vi:4350001->Executor.lvlib:Execute test vi Msg.lvclass:Do.vi:3750001->Actor Framework.lvlib:Actor.lvclass:Receive Message.vi:1040002->Actor Framework.lvlib:Actor.lvclass:Actor Core.vi:5880002->Executor.lvlib:Executor.lvclass:Actor Core.vi:5880001->Actor Framework.lvlib:Actor.lvclass:Actor.vi:6640009->Actor Framework.lvlib:Actor.lvclass:Actor.vi.ACBRProxyCaller.6CB00000 Possible reason(s): LabVIEW: Failed to load dynamic library because of missing external symbols or dependencies, or because of an invalid file format. ========================= Shareable board exclusively owned.
(3,825 Views)
Accepted by topic author Griffin-Ning
Hi, may I confirm some details with you first?
  1. Is it “running the .exe” and “running compile environment” both are same computer?
If no, maybe in current computer does not have sub VI /document which you used in application, so the application failed to call.
Remember just put all needed VI/document in the same directory with application.exe.
  1. Check all the file path in block diagram, use VI such as “Application directory” to create relative file path instead absolute file path.
  1. You may check the following solution to find the missing dependencies.
Error 13 at Call Library Function Node When Trying to Open DLL in LabVIEW - National Instruments (ni...
We can discuss at here again if you face any difficulties during your troubleshooting.
(3,755 Views)
Tks you for your suggestion,i found that i lost some .dll and some path error like what you said.
And now i can create the .exe successfully.I hope that we can discuss more about LabVIEW or some interesting tools here,tks you again!😀
(3,746 Views)
Hi Ning,
I am having the same error while creating executable. My OS Win-10 64 bit
Could share the dlls what exactly you included in your application.
 I tried to include following dlls.
Your answer would be greatly helpful
(3,621 Views)
