Solving linear equation
Is any formula to solve the below equation in LabVIEW
3*x^1/2+2*x+7*x^3/2+2*x^2+5*x^5/2=2
Thanks in advance
Message 1 of 10
(7,017 Views)
If you have a formula, it does not depend on the programming language. Nothing to do with LabVIEW.
Is x guaranteed to be positive?
If you don't have a formula, you could e.g. use e.g.  Newton-Raphson with a few iterations starting with a reasonable guess. A nice programming exercise. 😄
Message 2 of 10
(7,008 Views)
Have you tried using the formula node?
Message 3 of 10
(6,955 Views)
It is "=2", not "+2" and he wants to solve for x.
Message 4 of 10
(6,949 Views)
Yeah I know,  I wasn't sure if I was being too simple but assumed that he would know to rewrite the equation so that 2( as a variable) is the input and X is the output.
X= 0.222647?
Message 5 of 10
(6,937 Views)
Thanks to everyone for your valuable inputs.
Atlast i solved the equation by doing some modifications in the vi which i downloaded from forum and am attaching the same vi here
Message 6 of 10
(6,919 Views)
When quoting somethings from the forum, please include a link! Do you have a link?
Why is the VI so messy?
Message 7 of 10
(6,884 Views)
Don't forget that there will be quite a few more roots, some complex. In this case, there is one real root and you can find it as follows using this VI. (Of course you need to make certain assumptions about x). In the more general case, use this VI to sort out the real roots.
Message 8 of 10
(6,881 Views)
As mentioned earlier here is the link where i got vi to solve the equation https://forums.ni.com/t5/LabVIEW/Solving-Math-Expression-using-Labview/td-p/2113376
Message 9 of 10
(6,870 Views)
The „Solve Linear Equations VI“  works differently in PC and in Realtime. When I run the attached VI in the PC (without compilation) it gives TRUE. The same VI when I run in Real time Project (cRIO – with compilation) it gives FALSE.
I have gone through the VIs and I found different function for different target (Default & RT Target). Why its different for various target? The result without compilation (Default) is correct value. How I can use that?
Whether the DLL format is not supported by Realtime?
Thanks & Regards,
Shree
Message 10 of 10
(6,429 Views)
