Solve this
Hi Friends,
          I am having one  Matrix X of order mxn. I need to perform this operation.
Variable Y=  X- (Mean of X) .
The mean of Matrix is a column matrix. how to solve this equation.  The matrix size can vary dynamically.. how to solve this equation. Please help me out
Message 1 of 10
(5,274 Views)
Hi deepak.aamecece,
you can use the MEAN.vi. It works with arrays.
Mike
Message 2 of 10
(5,257 Views)
Message 3 of 10
(5,243 Views)
hi deepak,
  I could not understand your question?Why are you trying to substract a matrix from a column vector(mean)?
Thanks and regards,
srikrishnaNF
Srikrishna
Message 4 of 10
(5,228 Views)
Mathematically speaking, you cannot subtract a column matrix from a "rectangle" matrix. You may add or subtract only with equal size matrices.
What do you mean with X- (Mean of X)?
Paolo
Message 5 of 10
(5,227 Views)
Hi...
Let X is a matrix of size  4x4. The mean of (X) is a Column matrix. I know it is not possible in mathematics... but I need to subtract this for the application need... How to do this?
Message 6 of 10
(5,167 Views)
hi deepak,
  Only thing you can do is you can reshape the column matrix to a 4x4  and perform the operation you want..
Thanks and regards,
srikrishnaNF
Srikrishna
Message 7 of 10
(5,163 Views)
Hi...Friends.. I Solved this problem.Thank you for your help
Message 8 of 10
(5,122 Views)
Hi deepak.aamecece,
can you please show your solution, to help to understand what we missed with all the trials to help you?
Thanks in advance
Mike
Message 9 of 10
(5,114 Views)
 Hi Friends.. I solved like this... Please find the attached jpg file....What i did is: matrix X is 4x4 matrix. Mean of Matrix X is a Column matrix. I separated the first column of a matrix X. I subtracted from Column matrix and i appended back the result to the original matrix..
Thank you one and all for your effort you had taken to help me in this regard.
Message 10 of 10
(5,097 Views)
